How do I get the feature class name of layers that has lost there connections?
3244
04-02-2012 10:11 AM
GenaroGarcia
I???m in the need of get the feature class name of layers that lost their connections to SDE, broken data source.
They would contain a Red Explanation mark at the end of layer name located in the Table of Contents of ArcMap.
If you right-click on a layer and then select "Properties", the Layer Properties dialog is displayed.
Within the dialog there is a "Source" tab" that displays the Data Source information.
I need to retrieve the "Feature Class" information.
Any ideas, suggestions are appreciated...
by Anonymous User
Not applicable
Original User: jtkknelson
http://forums.arcgis.com/threads/50884-Programmatically-Identifying-Broken-Data-Links
Some old code below
Dim pEnumLayer As IEnumLayer, pdLayer As IDataLayer
layer = GetPath(pdLayer.DataSourceName)
            Valid = aLayer.Valid
Private Function GetPath(pDSName As IDatasetName) As String
    On Error Resume Next
    Dim DataType As String
    Dim genUtils As New clsGeneralUtilities
    GetPath = pDSName.WorkspaceName.PathName
    DataType = pDSName.Category
    If TypeOf pDSName Is IFeatureClassName Then
        Dim pFCName As IFeatureClassName
        Set pFCName = pDSName
        If Not pFCName.FeatureDatasetName Is Nothing Then
            GetPath = GetPath & "\" & pFCName.FeatureDatasetName.Name
        End If
    End If
    If pDSName.Name <> "point" And pDSName.Name <> "polygon" And pDSName.Name <> "arc" Then
       If Not DataType = "Shapefile Feature Class" Then
          GetPath = GetPath & "," & pDSName.Name
       Else
          GetPath = GetPath & "," & pDSName.Name & ".shp"
       End If
   Else
       GetPath = pDSName.WorkspaceName.PathName & "," & pFCName.FeatureDatasetName.Name
   End If
End Function
by Anonymous User
Not applicable
Some old code below
        End If
    End If
       Else
       End If
   Else
   End If
End Function
GenaroGarcia
We came up with a easier solution that feeds our needs:
                // --- create reference to ArcMap document
                IDocument doc = arcMapDoc.Document;
                // --- QI to IMXDocument
                IMxDocument mxDoc = doc as IMxDocument;
                // --- create reference to focus map
                IMap map = mxDoc.ActiveView.FocusMap;
                // --- create layers enumeration
                IEnumLayer layerEnum = map.get_Layers(null, true);
                // --- retrieve first layer
                ILayer layer = layerEnum.Next() as ILayer;
                // --- loop while layer is valid
                while (layer != null)
                    // --- QI to data layer
                    IDataLayer2 dataLayer = layer as IDataLayer2;
                    // --- test for valid data layer
                    if (dataLayer != null)
                        // --- QI to dataset name
                        IDatasetName2 datasetName = dataLayer.DataSourceName as IDatasetName2;
                        MessageBox.Show("DataSet Name: " + datasetName.Name.ToString());
                        // --- test for valid dataset name
                        if (datasetName != null)
