How do I get an existing ArcMap context menu so I can add a custom command to it?
2061
05-05-2011 01:49 PM
DirkVandervoort
The title says it all. All I'm asking for is an entry into this problem.
I want to add some custom commands I have written to a context menu that already exists (the one that defaults when you right-click the active data view actually).
I imagine I can get the context menu using a GUID or name, and I'm pretty sure that there are methods that allow me add a command using its GUID or name to the context menu.
But I can't seem to get past the concept to start seeing the design and code :mad:
TIA
nikhilsastikar
Below code might help..
Sub main()
Dim pUid As New UID
pUid.Value = "{3846A5B5-D3F8-44CB-BFA3-A5C30F4E535F}" ' Data view context menu
Dim pCmdBar As ICommandBar
Set pCmdBar = Application.Document.CommandBars.Find(pUid)
' Add some built-in ArcMap commands to the new toolbar
  pCmdBar.Add ArcID.File_AddData
pCmdBar.Popup
End Sub
Nikhil
