How can I draw a freehand polygon?
4104
05-10-2011 01:21 PM
KenBuja
MVP Esteemed Contributor
I'm creating an Add-in that lets a user select the type of feature to draw on the map. I've gotten the code for adding points, polygons, and rectangles, but I'd like to add in the capability of drawing polygons in freehand mode. Is there way of doing that? Here's my existing code for the drawing tool
Public Class DrawTool
    Inherits ESRI.ArcGIS.Desktop.AddIns.Tool
    Public Sub New()
    End Sub
    Protected Overrides Sub OnUpdate()
    End Sub
    Protected Overrides Sub OnMouseDown(ByVal arg As ESRI.ArcGIS.Desktop.AddIns.Tool.MouseEventArgs)
        MyBase.OnMouseDown(arg)
        Dim activeView As ESRI.ArcGIS.Carto.IActiveView = My.ArcMap.Document.ActiveView
        Dim rgbColor As ESRI.ArcGIS.Display.IRgbColor = New ESRI.ArcGIS.Display.RgbColorClass()
        Dim pGeometry As ESRI.ArcGIS.Geometry.IGeometry5 = GetFeatureFromMouse(activeView)
        rgbColor.Red = 255
        'Add the user's drawn graphics as persistent on the map.
        AddGraphicToMap(activeView.FocusMap, pGeometry, rgbColor, rgbColor)
        'Best practice: Redraw only the portion of the active view that contains graphics.
        activeView.PartialRefresh(ESRI.ArcGIS.Carto.esriViewDrawPhase.esriViewGraphics, Nothing, Nothing)
    End Sub
    Public Sub AddGraphicToMap(ByVal map As ESRI.ArcGIS.Carto.IMap, ByVal geometry As ESRI.ArcGIS.Geometry.IGeometry, ByVal rgbColor As ESRI.ArcGIS.Display.IRgbColor, ByVal outlineRgbColor As ESRI.ArcGIS.Display.IRgbColor)
        Dim graphicsContainer As ESRI.ArcGIS.Carto.IGraphicsContainer = CType(map, ESRI.ArcGIS.Carto.IGraphicsContainer) ' Explicit Cast
        Dim element As ESRI.ArcGIS.Carto.IElement = Nothing
        graphicsContainer.DeleteAllElements()
        If (geometry.GeometryType) = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPoint Then
            ' Marker symbols
            Dim simpleMarkerSymbol As ESRI.ArcGIS.Display.ISimpleMarkerSymbol = New ESRI.ArcGIS.Display.SimpleMarkerSymbolClass()
            simpleMarkerSymbol.Color = rgbColor
            simpleMarkerSymbol.Outline = True
            simpleMarkerSymbol.OutlineColor = outlineRgbColor
            simpleMarkerSymbol.Size = 8
            simpleMarkerSymbol.Style = ESRI.ArcGIS.Display.esriSimpleMarkerStyle.esriSMSCross
            Dim markerElement As ESRI.ArcGIS.Carto.IMarkerElement = New ESRI.ArcGIS.Carto.MarkerElementClass()
            markerElement.Symbol = simpleMarkerSymbol
            element = CType(markerElement, ESRI.ArcGIS.Carto.IElement) ' Explicit Cast
        ElseIf (geometry.GeometryType) = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolyline Then
            '  Line elements
            Dim simpleLineSymbol As ESRI.ArcGIS.Display.ISimpleLineSymbol = New ESRI.ArcGIS.Display.SimpleLineSymbolClass()
            simpleLineSymbol.Color = rgbColor
            simpleLineSymbol.Style = ESRI.ArcGIS.Display.esriSimpleLineStyle.esriSLSSolid
            simpleLineSymbol.Width = 5
            Dim lineElement As ESRI.ArcGIS.Carto.ILineElement = New ESRI.ArcGIS.Carto.LineElementClass()
            lineElement.Symbol = simpleLineSymbol
            element = CType(lineElement, ESRI.ArcGIS.Carto.IElement) ' Explicit Cast
        ElseIf (geometry.GeometryType) = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolygon Then
            ' Polygon elements
            Dim simpleFillSymbol As ESRI.ArcGIS.Display.ISimpleFillSymbol = New ESRI.ArcGIS.Display.SimpleFillSymbolClass()
            simpleFillSymbol.Color = rgbColor
            simpleFillSymbol.Style = ESRI.ArcGIS.Display.esriSimpleFillStyle.esriSFSForwardDiagonal
            Dim fillShapeElement As ESRI.ArcGIS.Carto.IFillShapeElement = New ESRI.ArcGIS.Carto.PolygonElementClass()
            fillShapeElement.Symbol = simpleFillSymbol
            element = CType(fillShapeElement, ESRI.ArcGIS.Carto.IElement) ' Explicit Cast
        End If
        If Not (element Is Nothing) Then
            element.Geometry = geometry
            graphicsContainer.AddElement(element, 0)
        End If
    End Sub
    Public Function GetFeatureFromMouse(activeView As ESRI.ArcGIS.Carto.IActiveView) As ESRI.ArcGIS.Geometry.IGeometry5
        Dim screenDisplay As ESRI.ArcGIS.Display.IScreenDisplay = activeView.ScreenDisplay
        Dim pPointSymbol As New ESRI.ArcGIS.Display.MarkerFillSymbol
        Dim pRGBColor As New ESRI.ArcGIS.Display.RgbColor
        Dim pPolygonSymbol As New ESRI.ArcGIS.Display.SimpleFillSymbol
        Dim pOutline As New ESRI.ArcGIS.Display.SimpleLineSymbol
        Dim pRubberBand As ESRI.ArcGIS.Display.IRubberBand2
        Try
            Select Case Globals.DrawFeatureType
                Case "Point"
                    pRubberBand = New ESRI.ArcGIS.Display.RubberPoint
                 Case "Polygon"
                    pRubberBand = New ESRI.ArcGIS.Display.RubberPolygon
                Case "Rectangle"
                    pRubberBand = New ESRI.ArcGIS.Display.RubberEnvelope
                Case "Freehand"
                    System.Windows.Forms.MessageBox.Show("Freehand not coded yet")
                    Return Nothing
                Case Else
                    System.Windows.Forms.MessageBox.Show("Not coded yet")
                    Return Nothing
            End Select
            pGeometry = pRubberBand.TrackNew(screenDisplay, Nothing)
            Return pGeometry
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Get Feature")
            Return Nothing
        End Try
    End Function
End Class
by Anonymous User
Not applicable
Ken,
In the editor we use the INewBezierCurveFeedback interface to provide feedback for the freehand tools. This works a little differently from the simple rubber band classes though.
The code example below uses the feedback to populate a sketch for an edit task. In your case you would just need to take the returned polyline geometry and convert it to polygon.
    private INewBezierCurveFeedback m_LineFeedback = null;
    protected sealed override void OnMouseDown(MouseEventArgs arg)
      IPoint point = m_editor.Display.DisplayTransformation.ToMapPoint(arg.X, arg.Y);
      if (m_LineFeedback == null)
        //first mouse click - start feedback
        m_LineFeedback = new NewBezierCurveFeedbackClass();
        m_LineFeedback.Display = m_editor.Display;
        m_LineFeedback.Start(point);
      else
        //second mouse click - end feedback and create feature
        IPolyline polyline = m_LineFeedback.Stop();
        IEditSketch editSketch = m_editor as IEditSketch;
        editSketch.Geometry = polyline;
        editSketch.FinishSketch();
      base.OnMouseDown(arg);
    protected sealed override void OnMouseMove(MouseEventArgs arg)
      if (m_LineFeedback != null)
        m_LineFeedback.AddPoint(point);
      base.OnMouseMove(arg);
by Anonymous User
Not applicable
Ken,
      else
KenBuja
Thanks, Sean. This is what my code now looks like
    Private m_LineFeedback As ESRI.ArcGIS.Display.INewBezierCurveFeedback = Nothing
    Public Sub New()
    End Sub
    End Sub
        Try
            Dim pGeometry As ESRI.ArcGIS.Geometry.IGeometry5 = GetFeatureFromMouse(activeView, arg.X, arg.Y)
            If pGeometry Is Nothing Then Exit Sub
            rgbColor.Red = 255
            System.Windows.Forms.MessageBox.Show(ex.ToString)
        End Try
    End Sub
    Protected Overrides Sub OnMouseMove(arg As ESRI.ArcGIS.Desktop.AddIns.Tool.MouseEventArgs)
        MyBase.OnMouseMove(arg)
        Try
            If m_LineFeedback IsNot Nothing Then
                Dim pPoint As ESRI.ArcGIS.Geometry.IPoint = My.ArcMap.Document.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(arg.X, arg.Y)
                m_LineFeedback.AddPoint(pPoint)
            End If
        End Try
    End Sub
            ' Marker symbols
            '  Line elements
        ElseIf geometry.GeometryType = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolygon Then
            ' Polygon elements
        ElseIf geometry.GeometryType = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryEnvelope Then
            Dim fillShapeElement As ESRI.ArcGIS.Carto.IFillShapeElement = New ESRI.ArcGIS.Carto.RectangleElementClass
        End If
            Try
            End Try
        End If
    End Sub
    Public Function GetFeatureFromMouse(activeView As ESRI.ArcGIS.Carto.IActiveView, XVal As Integer, YVal As Integer) As ESRI.ArcGIS.Geometry.IGeometry5
        Dim pPolygon As ESRI.ArcGIS.Geometry.IPolygon4
        Dim pPolyLine As ESRI.ArcGIS.Geometry.IPolyline6
        Try
                Case "Point"
                    pPoint = pRubberBand.TrackNew(screenDisplay, Nothing)
                    Return pPoint
                Case "Polygon"
                    pPolygon = pRubberBand.TrackNew(screenDisplay, Nothing)
                    Return pPolygon
                Case "Rectangle"
                    Return pGeometry
                Case "Freehand"
                    pPoint = activeView.ScreenDisplay.DisplayTransformation.ToMapPoint(XVal, YVal)
                    If m_LineFeedback Is Nothing Then
                        m_LineFeedback = New ESRI.ArcGIS.Display.NewBezierCurveFeedback
                        m_LineFeedback.Display = screenDisplay
                        m_LineFeedback.Start(pPoint)
                        Return Nothing
                    Else
                        pPolyLine = m_LineFeedback.Stop
                        m_LineFeedback = Nothing
                        pPolygon = CreatePolygonfromPolyline(pPolyLine)
                        Return pPolygon
                    End If
                Case Else
                    Return Nothing
            End Select
            Return Nothing
        End Try
    End Function
    Private Function CreatePolygonfromPolyline(pPolyline As ESRI.ArcGIS.Geometry.IPolyline6) As ESRI.ArcGIS.Geometry.IPolygon4
        Try
            Dim pOutCollection As ESRI.ArcGIS.Geometry.IPointCollection4 = New ESRI.ArcGIS.Geometry.Polygon
            pOutCollection.AddPointCollection(pPolyline)
            pPolygon = pOutCollection
            pPolygon.Close()
            Return pPolygon
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Conversion error")
            Return Nothing
        End Try
    End Function
End Class
