Help with Snapping on Custom Tools
1450
02-22-2013 04:15 AM
Corbinde_Bruin
I'm having trouble with following the basic snapping instructions
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#//0001000001s1000000
I can see these Interfaces in the API reference, but they come up as undefined when I try to use them in code.
ISnappingEnvironment
IPointSnapper
ISnappingFeedback
I have ESRI.ArcGIS.Geometry referenced.
Does anyone have working 10.1 code for snapping. I am attempting to use this functionality outside of an edit session.
Thank you,
Corbin de Bruin
NeilClemmons
Honored Contributor
The library you need to reference is listed at the top of the help pages for these interfaces.  In this case, it is the Controls library.
NeilClemmons
Honored Contributor
by Anonymous User
Not applicable
Corbin,
The following blog post may also be of help.
Incorporating snapping into custom tools
Corbinde_Bruin
Yes it is, thank you. I had already been using that, just totallly missed the "control" reference statement. Must have looked at it a million times.
