GxDialog.ReplacingObject with geodatabase
943
03-06-2011 10:28 PM
JanBurdziej1
I'm using GxDialog to save a feature class, which can be a shp or a pgdb / fgdb feature class. I want to know whether to overwrite existing fc. I'm using pGxDialog.ReplacingObject property. It works fine for shapefiles (i.e. msgbox shows up and the pGxDialog.ReplacingObject  property is set accordingly), but when I change GxFilter to Geodatabase it doesn't work.
I've seen some older discussions on the forum on this topic, it seems it was a bug earlier (http://forums.esri.com/thread.asp?c=93&f=1727&t=147425). Does anyone knows if ESRI has fixed it?
Regards,
Jan
