Get the shortest line between 2 features
883
10-24-2011 05:49 AM
EtienneDeschenes
Hello,
I'm trying to draw (and save in a feature class) the shortest line between two features (lines).
I can get the shortest distance with the IProximityOperator but I can't find a way to get the actual line (or both points, or angle and point of origin like the generate near table does).
Thank you!
Etienne
DuncanHornby
MVP Notable Contributor
Etienne,
The IProximityOperator Interface has a method called ReturnNearestPoint.  You would get a handle on your 2 lines and use this method in both directions to build an ILine geometry from the 2 points?
Duncan
