GDI+ Smooth Edge Draw Issue
7059
10
07-11-2010 09:37 AM
by Anonymous User
Not applicable
Original User: dberry911
I am using VS2005 VB.NET with ArcObjects V9.3.1.
I am using GDI+ to DrawImage, DrawString, DrawEllipse as part of an AVL Tracking Layer(non-dynamic map).
Resulting images, text, and ellipsis are not drawn smooth, they appear as having rough edges.
Using the same code in a test application results in all images & text with smooth edges.
The GDI+ MeasureString method calculates inaccurate values, but in the test application calculations are correct.
When DrawText is used with a background the text has smooth edges, but if drawn directly on the MapControl the text has rough edges.
I am setting the SmoothingMode of the graphics to Antialias and have tried every other combination without success.
Attached are examples of rough & smooth edges of an ellipse.
Anyone else see this same issue?
Suggestions & insights appreciated.
Regards,
Dennis
DennisBerry
Kirk,
I had tried once before commenting-out the start/finish draw to no affect.
This logic is all pretty simple and it's my feeling that there is some type of underlying issue, but what that is I have no idea.
Does anyone from ESRI have any suggestions to offer?
And again it doesn't matter where I do the draw it all results in rough edges.
Regards,
Dennis
