Function call when adding or removing ArcGIS Server Map Services
889
07-18-2011 01:48 PM
AdamLake
I am working on improving the performance of a server object extension by caching some data in memory that does not change once a map service is added to the server.  I would like to change my cache to write the data to a file so I can free up some memory and avoid the computational overhead from recreating the cache every time an instance of the service is created.  I know how to structure the cache, but I have one problem.  I need to figure out if a service is deleted from the server so I can clear out the file cache.  Often times services are deleted and then an updated version is added, at which point I need to update the cache.  If I can trigger an event that deletes the cache associated with a service when that service is deleted, I think I can really improve the performance of the extension.
Thanks in advance,
Adam Lake
Echo Lake Consulting
RichardWatson
I think that the services are stored in a file on the file system.  If that is the case then you can simply watch that file and read it when it changes to see if your service was deleted.
