Field Calculation of Selected Features - Problem With VBA Code
908
05-20-2010 06:54 AM
ShanaLowe
I have created some tools for a scheduling project.  It allows the user to select a layer (multiple layers that they need to schedule), select features and then there is a user form that allows them to select an employee number from a drop-down box and that value gets assigned to a particular field of the selected features.  It seems to work most of the time, but sometimes I get an error if I try to do a manual calucation afterwards and then it does not seem to work until I close and reopen the application.  I am attaching the code for the "Assign" button (which does the field calculation) and was wondering if someone could take a look at it and see if they could spot some obvious errors with the code.
Thank you in advance!
Private Sub cmdAssign_Click()
  On Error GoTo EH
  Dim pDoc As IMxDocument
  Set pDoc = ThisDocument
  ' Get the layer that is selected in the TOC
  Dim pFeatLayer As IFeatureLayer
  Dim pFeatClass As IFeatureClass
  Dim pUnKnown As IUnknown
  Set pUnKnown = pDoc.SelectedLayer
  If pUnKnown Is Nothing Then
    MsgBox "Must have a layer selected in the table of contents."
    Exit Sub
  End If
  Set pFeatLayer = pUnKnown
  Set pFeatClass = pFeatLayer.FeatureClass
  Dim pFSel As IFeatureSelection
  Dim pSS As ISelectionSet2
  Set pFSel = pFeatLayer
  Set pSS = pFSel.SelectionSet
  If pSS.Count = 0 Then
    MsgBox "Please select one or more features before assigning work"
    Exit Sub
  End If
'perform calculation
  Dim pCursor As IFeatureCursor
  pSS.Update Nothing, True, pCursor
Dim pCalc As ICalculator
Set pCalc = New Calculator
  Dim srEmployee As String
  strEmployee = cboEmp1.Text
   With pCalc
      Set .Cursor = pCursor
      .Expression = strEmployee
      .Field = "EMPSCHEDULED1"
   End With
  pCalc.Calculate
  frmSchedule.Hide
  Exit Sub
EH:
  MsgBox Err.Number & "  " & Err.Description
End Sub
JamesCrandall
I have no idea if this would help, or if it's even related to the issue you are having, but have you tried starting/stopping an edit session before/after your calc process?
