Exporting to PDF Layout in CM, output is in INCHES - the same number as CM
1244
03-11-2011 09:55 AM
JeremyWiles
When I export programatically using IExport and implement Output.ExportPDF, and the layout in in centimeters, I should get a page that measures 11 x 17" (or 43.18 cm x 27.94 cm). The PDF turns out to be 43.18 x 27.94", which would be correct if the units were Centimeters, but they are inches.
Is this a known bug, or has anybody else run into this before?
Jeremy Wiles
GIS Developer
UniversalPegasus Inc.
TomSchuller
Hy,
may be my Java code can help you:
http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
Take care to download the latest version.
Tom
