Export to GeoJPEG
2402
11-23-2011 06:10 AM
RobertoSpedale
Hi
I'am trying to export map in a geo image (with world file) by vba arcobject.
My script only works if I use "TiffExporter" CoClass but if I use "ExportJPEG" or "JPEGExporter" it doesn't work and I have error on line 23 of the script (in attach).
does anyone know what could be the problem?
many thanks!
Roberto
KenBuja
MVP Esteemed Contributor
Which version of ArcGIS are you using? For ArcGIS 9 and above, you should be using IExport instead of IExporter, along with ExportTIFF and ExportJPEG instead of TiffExporter and JPEGExporter.
RobertoSpedale
Many many thansk kenbuja!
I use ArcGIS 9.0 and using IExport with ExportJPEG it's work!
