export arcsde feature layer to mdb table by changing the value of vertex xy value
4212
08-23-2015 06:23 PM
Ye_FengFeng
Hi there,
I need to export arcsde feature layer to mdb table, but I need to change the vertex xy value (2 decimals and need to run down on the 3rd value. What I can do now is set th xy resolution to 0.01, but by using this method if the 3rd decimal is 5-9, the 2nd decimal will add 1, what I want is no matter what is the 3rd decimal value, just remove it).
I am using .net arcobjects 9.2.
Is it possible to get the result I want?
Thanks in advance.
ModyBuchbinder
Hi
This question belong to the ArcObject SDK and not the runtime.
If I understand the question you must go vertex by vertex and write them again in the way you like.
Something like newVertex.X = round(oldVertex.X + 0.5)
Have fun
Mody
Ye_FengFeng
Hi Mody,
Thank you for the reminding. I will put it in the arcobjects part.
Currently my problem is how can I get the xy value for all vertex before I perform further calculation.
ModyBuchbinder
Cast any geometry into IPointCollection
