We need to export a feature dataset (including number of feature classes) and, not in the dataset, number of tables, to a file geodatabase (FGDB).
The source is some data in memory (not in memory feature class) on runtime. The target - a FGDB created programmatically.
And the schema must be taken from a current enterprise database (meaning we only export what current schema contains)
We cannot use a FGDB template.
Is any ArcObjects API able to do it?
Something like
1) Exporting a geodatabase schema to an XML workspace document
2) Importing a geodatabase schema from an XML workspace document
3) ...
Any other ideas will be appreciated.
C#, ArcGIS 10.6.1, no Python
Solved! Go to Solution.
Hi Mark,
We use IGdbXmlImport and IGdbXmlExport for schema importing/exporting. But we work with personal or file geodatabases. I have not tried to use them on enterprise database.
It could be some problems if your database contains Schematic stuff.
Hi Mark,
