Export a pageLayout to PDF in ArcObjects
7788
9
01-18-2011 08:08 AM
JMJJDJM
Hi
We are migrating an application in 9.2 to version 10.
The following VB code. NET converted to PDF in version 9.2 but returns a blank page used in Arcgis 10.
Anyone know how to export to PDF the active layout (SDK. NET ArcGis 10)?
Thanks in advance (JMJ98)
'variables
        Dim lScrRes As Long
        Dim pExporter As IExporter
        Dim deviceRECT As tagRECT
        Dim pDriverBounds As IEnvelope
        Dim pCancel As ITrackCancel
        Dim nomExportacio As String
        Dim pExport As IExport
        Dim iScreenResolution As Integer
        Dim iOutputResolution As Integer
        Dim exportRECT As tagRECT
        Dim pPixelBoundsEnv As IEnvelope
        Dim hdc As Long
        Dim deviceFrameRect As tagRECT
        Dim pActiveView As IActiveView
        Dim tmpDC As Long
        Dim faExportacio As Boolean
        Dim formatoImagen As String
        Dim pMxDoc As IMxDocument
        Dim objFactory As IObjectFactory
        Dim nom As String
        Dim pageL As IPageLayout
        Dim map As IMap
        Dim psi As New ProcessStartInfo()
            faExportacio = False
            pActiveView = pMxDoc.PageLayout
            pageL = New PageLayout
            pageL = pActiveView
    If formatoImagen = "PDF" Then
                pExporter = objFactory.Create("esriOutput.PDFExporter")
                nomExportacio = nom
                pExporter.ExportFileName = nomExportacio
                With deviceFrameRect
                    .left = 0
                    .right = 800
                    .top = 0
                    .bottom = 600
                End With
                'pActiveView.ScreenDisplay.DisplayTransformation.DeviceFrame = deviceFrameRect
                tmpDC = GetDC(0)
                iScreenResolution = GetDeviceCaps(tmpDC, 88)  '88 is Win32 constant for LOGPIXELSX
                ReleaseDC(0, tmpDC)
                iOutputResolution = 1200
                pExporter.Resolution = iOutputResolution
                With exportRECT
                    .left = pActiveView.ExportFrame.left * (iOutputResolution / iScreenResolution)
                    .top = pActiveView.ExportFrame.top * (iOutputResolution / iScreenResolution)
                    .right = pActiveView.ExportFrame.right * (iOutputResolution / iScreenResolution)
                    .bottom = pActiveView.ExportFrame.bottom * (iOutputResolution / iScreenResolution)
                End With
                pPixelBoundsEnv = New Envelope
                pPixelBoundsEnv.PutCoords(exportRECT.left, exportRECT.top, exportRECT.right, exportRECT.bottom)
                pExporter.PixelBounds = pPixelBoundsEnv
                hdc = pExporter.StartExporting
                pCancel = New CancelTracker
                pActiveView.Output(hdc, iOutputResolution, exportRECT, pageL.Page.PrintableBounds, pCancel)
                pExporter.FinishExporting()
                faExportacio = True
                psi.FileName = System.Windows.Forms.Application.StartupPath.ToString & "\tmp\" & cmbParametro.Text & ".pdf"
                Process.Start(psi)
    End If
Venkata_RaoTammineni
Hi
'variables
        Dim lScrRes As Long
        Dim hdc As Long
        Dim tmpDC As Long
        Dim nom As String
        Dim map As IMap
            pageL = pActiveView
                nomExportacio = nom
                    .left = 0
                    .right = 800
                    .top = 0
                    .bottom = 600
                End With
                tmpDC = GetDC(0)
                ReleaseDC(0, tmpDC)
                With exportRECT
                End With
                faExportacio = True
                Process.Start(psi)
    End If
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#//00380000003n000000
http://help.arcgis.com/en/sdk/10.0/arcobjects_cpp/componenthelp/index.html#//0017000000t3000000
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/d/000100000026000000.ht...
JohnHauck
I've not had a chance to step through the code yet but wanted to at least mention that the ArcPy site package has simple functions to export to pdf. We have documentation in the SDK regarding calling python scripts from .NET if this sounds like an alternative you may be interested in.
JMJJDJM
Hi
This sample runs me ok, inside ArcGis 10.
But if runs in a windows form application (with automated arcgis opened), the result its  blank PDF.
Please, Anyone can you help me ??
JMJ98
Sample for SDK Argis 10:
Public Sub ExportActiveViewParameterized(ByVal ExportFormat As String, ByVal iOutputResolution As Long, ByVal lResampleRatio As Long, ByVal bClipToGraphicsExtent As Boolean)
        'Export the active view using the specified parameters
        Dim docActiveView As IActiveView
        Dim docExport As IExport
        Dim docPrintAndExport As IPrintAndExport
        Dim RasterSettings As IOutputRasterSettings
        Dim sNameRoot As String
        Dim sOutputDir As String
        Dim bReenable As Boolean
        If (GetFontSmoothing()) Then
            bReenable = True
            DisableFontSmoothing()
                MsgBox("Cannot Disable Font Smoothing.  Exiting.")
                Return
            End If
        End If
        docActiveView = My.ArcMap.Document.ActiveView
        ' Create an Export* object and cast the docExport interface pointer onto it.
        ' To export to any format, we simply create the desired Class here
        ExportFormat = "PDF"
        Select Case ExportFormat
            Case "PDF"
                docExport = New ExportPDF
            Case "EMF"
                docExport = New ExportEMF
            Case "BMP"
                docExport = New ExportBMP
            Case "EPS"
                docExport = New ExportPS
            Case "SVG"
                docExport = New ExportSVG
            Case "GIF"
                docExport = New ExportGIF
            Case "TIF"
                docExport = New ExportTIFF
            Case "JPEG"
                docExport = New ExportJPEG
            Case "PNG"
                docExport = New ExportPNG
            Case "AI"
                docExport = New ExportAI
            Case Else
                MessageBox.Show("Unrecognized output format, defaulting to EMF")
                ExportFormat = "EMF"
        End Select
        docPrintAndExport = New PrintAndExport
        ' Output Image Quality of the export.  The value here will only be used if the export
        '  object is a format that allows setting of Output Image Quality, i.e. a vector exporter.
        '  The value assigned to ResampleRatio should be in the range 1 to 5.
        '  1 corresponds to "Best", 5 corresponds to "Fast"
        If TypeOf docExport Is IOutputRasterSettings Then
          ' for vector formats, assign a ResampleRatio to control drawing of raster layers at export time
          RasterSettings = docExport
          RasterSettings.ResampleRatio = lResampleRatio
          ' NOTE: for raster formats output quality of the DISPLAY is set to 1 for image export
          ' formats by default which is what should be used
        End If
        'assign the output path and filename.  We can use the Filter property of the export object to
        ' automatically assign the proper extension to the file.
        sOutputDir = System.Environment.GetFolderPath(Environment.SpecialFolder.Personal) + "\"
        sNameRoot = "VBExportActiveViewSampleOutput"
        docExport.ExportFileName = sOutputDir & sNameRoot & "." & Right(Split(docExport.Filter, "|")(1), _
                                 Len(Split(docExport.Filter, "|")(1)) - 2)
        docPrintAndExport.Export(docActiveView, docExport, iOutputResolution, bClipToGraphicsExtent, Nothing)
        MessageBox.Show("Finished Exporting " & sOutputDir & sNameRoot & "." & Right(Split(docExport.Filter, "|")(1), _
                                 Len(Split(docExport.Filter, "|")(1)) - 2) & ".", "Export Active View Sample")
        'cleanup for the exporter
        docExport.Cleanup()
        If (bReenable) Then
            EnableFontSmoothing()
            bReenable = False
        End If
    End Sub
Hi
JMJ98
            bReenable = True
                Return
            End If
        End If
            Case "PDF"
            Case "EMF"
            Case "BMP"
            Case "EPS"
            Case "SVG"
            Case "GIF"
            Case "TIF"
            Case "JPEG"
            Case "PNG"
            Case "AI"
            Case Else
        End Select
        End If
        docExport.Cleanup()
        If (bReenable) Then
            bReenable = False
        End If
    End Sub
What do you mean by "if runs in a windows form application (with automated arcgis opened)"..Please can be clear on the same...or any screen ?
JMJJDJM
Hi  (sorry for my english)
From an application in VB.NET and try to open an ArcMap print your layout. (Automation)
We have included the sample code (ExportActiveView) and get a blank PDF.
In contrast, using the same example with ArcMap works perfectly.
JMJ98
JMJ98
Somehow you have to play with focus pagelayout... not basically activeview...
JMJJDJM
I tried to pass the PageLayout, but I have not worked.
In the attached image, you can see that the variables contain values (Debugger VS2008), but values should not be correct, because the PDF is generated blank
Thanks for your help.
JMJ98
JMJJDJM
I don't have a solution for export from .NET aplication to PDF.
VBA runs but the same code from my VB .NET application fails and returns a blank PDF. I think that error have a difficult solution ....
Maybe its the moment of on arcpy thinking, and see if runs.
Send me your vb.net code...
