Exception with ArcObjects 10 Address Standardizer
2025
03-02-2011 11:57 AM
RiamDjadri
Hello,
I'm having trouble with the new standardizer. The following code produces an exception on the second call to ParseAddressSample(). Any ideas ?
using System;
using System.Collections.Generic;
using System.Text;
using ESRI.ArcGIS.Geodatabase;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.DataSourcesGDB;
using ESRI.ArcGIS.Location;
namespace PopulateRC
    class Program
        private static IWorkspace pwps = null;
        private static AoInitialize _arcObjects = null;
        [STAThread]
        static void Main(string[] args)
            IWorkspaceFactory workspaceFactory = null;
            //ArcGIS10
            ESRI.ArcGIS.RuntimeManager.BindLicense(ESRI.ArcGIS.ProductCode.Engine);
            workspaceFactory = new FileGDBWorkspaceFactoryClass();
            //Path of file GDB.  Change it if necessary
            string connstr = @"C:\GisData\PowerMap.gdb";
            ArcObjectsStart();
            pwps = workspaceFactory.OpenFromFile(connstr, 0);
            if (pwps != null)
                //First, a classic case.  This one works!
                ParseAddressSample("10 main st");
                //Exception thrown with this string
                ParseAddressSample("main st");
            Console.WriteLine("Press any key to finish");
            Console.ReadLine();
        private static void ParseAddressSample(string freeFormat)
            LocatorManagerClass locatorManager = new LocatorManagerClass();
            ILocatorWorkspace locatorWorkspace = (ILocatorWorkspace)locatorManager.GetLocatorWorkspace(pwps);
            ILocator locator = locatorWorkspace.GetLocator("StreetSegment");
            if (locator != null)
                // Get the Locator and QI to ISimpleStandardization
                ISimpleStandardization standardizer = (ISimpleStandardization)locator;
                try
                    // Get the Standardization fields from the locator
                    //  exception on the 2nd call "Specified cast is not valid."
                    IPropertySet standardizedAddressSet = standardizer.SimpleStandardizeAddress(freeFormat);
                catch (Exception ex)
                    Console.WriteLine("Problem parsing (" + freeFormat + ") " + ex.Message);
        #region "ESRi licencing"
        #endregion
