ESRI.ArcGIS.Utility Not Installed With 10.2
3789
12-17-2013 11:35 AM
BrianBehling
According to this example:
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#//0023000000rr000000
I need to make a reference to ESRI.ArcGIS.Utility but that library is not registered or even installed with the SDK.
Is the example above not updated? If the ESRI.ArcGIS.Utility does not exist anymore, how can I set the mouse cursor to a custom mouse icon?
KenBuja
MVP Esteemed Contributor
By doing some searching in the 10.2 help, I was able to find the cursor methods and properties in the ESRI.ArcGIS.ADF.Local assembly here. These types of assemblies cannot be loaded with the "Add ArcGIS reference", but will be found in the "Add Reference" dialog.
BrianBehling
Thanks.
I was able to find that library now, but the example no longer works. The mouse icon seems to flicker, as if its trying to change the icon, then icon stays as an arrow and does not convert to the icon I specify.
