Errors when running Hillshade tool from within Visual Basic.Net code
1634
05-30-2013 05:02 PM
MakanKuat
Hi guys,
This is my first attempt of trying to run a tool from within Visual Basic.Net code. I do not know whats wrong as when I tried to run it on ArcMap10, I got this error
Unhandled exception has occured in a component in your application. If you click Continue, the application will ignore this error and attempt to continue
Error HRESULT E _FAIL has been returned from a call to a COM component
I think there's something wrong with my code below. I tried to search for information on the internet but couldnt find any. Appreciate if anyone is kind enough to have a look and correct my code below please. Thank you.
Private Sub Calculate_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Calculate.Click
        ' Initialize the geoprocessor.
        Dim gp As Geoprocessor = New Geoprocessor()
        Dim hillshadeTool As HillShade = New HillShade
        '  Local variables
        Dim kl23_dem As Object = "kl23_dem"
        Dim HillShadeOut As Object = "C:\\Users\\HillShadeTry"
        Dim parameters As IVariantArray = New VarArray
        ' Populate the variant array with parameter values.
        parameters.Add(kl23_dem)
        parameters.Add(HillShadeOut)
        parameters.Add("315")
        parameters.Add("45")
        parameters.Add("NO_SHADOW")
        parameters.Add("1")
        gp.Execute("Hillshade", parameters, Nothing)
    End Sub
martinmaretta
I think you have to use Path to your raster layer  instead of name.
' Local variables
Dim kl23_dem As Object = "C:\Users\kl23_dem"
Dim HillShadeOut As Object = "C:\Users\HillShadeTry"
parameters.Add("1")
End Sub
MakanKuat
Thank you, I have tried changing the name to path but still the same error message was displayed. Any suggestion why this is so and how to correct this?
' Local variables
parameters.Add("1")
End Sub
martinmaretta
OK try this one:  use !!! "Hillshade_sa"  !!!
Dim gp As IGeoProcessor2 = New GeoProcessor
parameters.Add("C:\Users\kl23_dem")
parameters.Add("C:\Users\HillShadeTry")
parameters.Add("1")
gp.Execute("Hillshade_sa", parameters, Nothing)
