Error with ArcEngine 10.3 Mapping
5012
01-12-2015 04:53 AM
PaulCole
I have just move over to Arc Engine 10.3 from 10.2 and re-compiled the software, but I am now getting an error being thrown up when trying to create A GDB File.
I am using the following code, it create the blank File GDB Database but when it comes to the workspaceFactory.Open instruction it throws up a COM Exception error of 0x80040228
IWorkspaceName workspaceName;
            propertySet = new PropertySetClass();
            workspaceFactory = new FileGDBWorkspaceFactory();
            DirectoryInfo di = new DirectoryInfo(directory + @"\" + fileName + ".gdb");
            if (di.Exists)
            else
                workspaceName = workspaceFactory.Create(amsDir, fileName + ".gdb", null, 0);
            propertySet.SetProperty("DATABASE", amsDir + @"\" + fileName + ".gdb");
            workspace = workspaceFactory.Open(propertySet, 0);
            IWorkspaceEdit workspaceEdit = (IWorkspaceEdit)workspace;
            workspaceEdit.StartEditing(true);
            workspaceEdit.StartEditOperation();
Under the license I am using the same as the 10.2 version ( ArcEngine & ArcEngine Enterprise GeoDatabase )
The ArcGIS administrator is showing that I have the EDN Subscription covering 10.3
I need a solution ASAP.
Paul Cole
FreddieGibson
Honored Contributor
Have you tried using the Activator to instantiate the workspace?
  // Instantiate a file geodatabase workspace factory and create a file geodatabase.
  // The Create method returns a workspace name object.
  Type factoryType = Type.GetTypeFromProgID(
   "esriDataSourcesGDB.FileGDBWorkspaceFactory");
  IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance
  (factoryType);
  IWorkspaceName workspaceName = workspaceFactory.Create(path, "Sample.gdb", null,
  0);
   // Cast the workspace name object to the IName interface and open the workspace.
  IName name = (IName)workspaceName;
  IWorkspace workspace = (IWorkspace)name.Open();
   return workspace;
Creating Geodatabase
http://help.arcgis.com/en/sdk/10.0/Arcobjects_net/conceptualhelp/index.html#//0001000004t8000000
