Error The type 'ESRI.ArcGIS.Geometry.SpatialReferenceEnvironmentClass' has no constru
6367
03-12-2012 05:33 AM
ShaningYu
Honored Contributor
I updated a .Net project from FW 3.5 to 4.0 (change the .Net FW target), I received a dozen of errors about No Constructors defined.  One of them is below:
Error  The type 'ESRI.ArcGIS.Geometry.SpatialReferenceEnvironmentClass' has no constructors defined
What should I do to solve this problem?  Thanks.
NeilClemmons
Honored Contributor
You can do that if you want but I've run into problems trying to use the 4.0 Framework with ArcObjects.  The majority of our code is still at 9.3.1 but if you're using 10.0 you may not run into the same problems.
NeilClemmons
Honored Contributor
The .NET Framework 4.0 is not currently supported.  You'll have to change the target framework back to 3.5.
ShaningYu
Honored Contributor
Use the approach posted at:
http://gis.stackexchange.com/questions/5782/no-constructor-defined
1)  In your project references, find the assembly where FeatureClassNameClass is (ie ESRI.ArcGIS.Geodatabase).
2)  Right-click it and select "properties"
3)  Change "Embed interop types" to "false"
The No-Constructor problem is gone.
BarbaraSchneider1
Thanks, this is what I was looking for
NeilClemmons
Honored Contributor
ShaningYu
Honored Contributor
Neil:
Thanks for your response.  Actually, the problem I got is that posted at
http://forums.arcgis.com/threads/52656-Error-HRESULT-E_FAIL-has-been-returned-from-a-call-to-a-COM-c......
Then I tried to change the FW from 3.5 to 4.0.  The No-Constructor problem appears to be gone (see my continued thread).  But the avobe error (HRESULT-E_FAIL) still exists.  Thanks.
Shaning
