Elevation SOE code ... upgrade 10.1
5111
14
07-02-2012 06:18 PM
IainCampion
hay @esri r u gonna update the elevation SOE sample to 10.1? since there is no code cant use it in 10.1, and it's bound to 10.0 .net objects
so when I register it in 10.1 is fails ?
Cheers
coomsie
JohnGrayson
Esri Alum
Thank you everybody for the continued support; we're getting close to releasing the Elevations SOE for 10.1.  We've had to make some breaking changes to accommodate requested use cases and it still needs some more testing.  Also, we're currently trying to add support for elevation datasets that have NoData values, something we have not done in the past.  We do not have a release date at this time, but I'll try to have it ready by the Dev Summit.
Please do not use this sample code in production environments or in mission critical situations; it's just a sample.
nicogis
Albert excuse me, if I have given you a wrong information.
nicogis
TristanKnowlton
Thank you!
BrianFischer
Will the .Net Elevations SOE 10.1.0 work with ArcGIS Server 10.2?
