Distance between and around two points to create a ratio between both  programtically
708
06-15-2010 10:34 AM
AndreaArratia
Hi all,
If somebody can help me with this ... I would really be thankful
I need to calculate the distance between two points and also I need to calculate the distance "around" two points (for example two points in a lake) and then make a ratio between them as many times as points there are in the shape file..... if you have a code that can help I would really happy!!!!
Thanks a lot,
Andre
