Creating a custom ArcMap class library in VB.Net
4706
07-22-2011 10:11 AM
GarySchells
I'm new to programming in  the .Net environment.  I am trying to create a custom ArcMap application that will allow users to automate a mailing labels task.  I've got something started in VB.Net.  I'm trying to understand some basics.  I come from the VBA environment.  My questions are"
1.  Is there a minimal number of modules required to create the application?  I have several tabs with .vb on the end that have been created.  I understand the "desighn" tab with my form and tools on it.  There is also a clsMain.vb that appears to have the code to "hooK' my application to ArcMap
2.  Is it similar to VBA in that I can design my form and tools and then double click the respective  tools to add the code?
I appreciate any feedback folks can provide.  I'm looking for a solid understanding of the basic requirements for ArcMap custom class creation in .Net.
thanks for any input
YaminiManickam
Hi!
Here is a good starting point to create applications for ArcGIS using .NET:
Extending ArcObjects - http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Extending_ArcObjects/00...
Creating commands and tools - http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Creating_commands_and_t...
Create a command by inheriting from BaseCommand - http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Walkthrough_Create_a_co...
Customizing ArcGIS Desktop using .NET is different from VBA in so many ways. Going through the above links will give you an idea.
To answer your questions:
Using the ArcGIS templates in Visual Studio will take care of the basic structure of the application. My suggestion is to follow the steps in the walkthrough in link 3 to get an idea.
As far as forms and tools are considered, yes, you should be able to double click on the tools to add code for the on click event.
I hope this helps.
YaminiManickam
An alternative is to build add-ins which are new in ArcGIS 10. For more information, please see:
Building add-ins for ArcGIS Desktop - http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Building_add_ins_for_Ar...
FYI, the add-in framework does not support every extensibility point defined by ArcGIS; for example, you cannot write a custom renderer, a custom workspace, or a custom feature as an add-in. You will need to use the classic COM extensibility approach(please see links provided in the previous post)if your solution includes component types that are unsupported in the add-in framework. Additionally, since the sharing of add-ins does not involve a registration step, do not use add-in based solutions that rely on external dependencies�??such as libraries, assemblies, and services�??that require registration or administrative intervention.
