CreateAddressLocator geocoding question
983
05-19-2010 01:38 PM
MarioSuau
I'm developing an application using ArcGIS Engine 9.3.  I want to be able to create an address locator in code.  I found an example that came with the dev kit called LocateAddress2008 and it shows me a lot of what I need to create a basic address locator.
From the example, I can see how to set the match fields.  My question is, how do I specify the values for things like minimum match score, spelling sensitivity, side offset, end offset, etc?
Thank you,
Mario Suau
Federal Signal Codespear
KirkKuykendall
see IGeoCodingProperties
MarioSuau
Thank you for pointing me in the right direction.  That did the trick.
Mario
