Create a KmlLayer using the ArcObjects Java API
1462
09-26-2011 07:37 PM
XtungBebei
How do you create a KmlLayer using the ArcObject Java API? I would like to then display that KmlLayer in a MapBean.
I've been able to load an ESRI Shapefile by creating a FeatureLayer using the ShapefileWorkspaceFactory and displaying that Feature Layer. I am trying to find a similar approach for loading a local KML file and displaying it in an ArcObject map using the Java API.
Thanks
xtungbebei
EricBader
Honored Contributor
You can only add a kml layer to a GlobeBean.
XtungBebei
Thanks. I have 2 follow up questions.
1. But if KmlLayer implements the ILayer interface then why couldn't I add it using a MapBean's addLayer method?
2. If I wanted to add it to a GlobeBean, is there some sample Java code around on how to create the KmlLayer from a local file?
Thanks
xtungbebei
