Correct SQL syntax when on Iworkspace.executeSQL
1465
07-12-2013 06:45 AM
HalilSiddique
Hi All,
I am working on a VBA app, and I am having trouble with running sql using the executeSQL method.
I have a table and a SDE featureclass, i want to insert all the records from a particular field from the featureclass into the table.
The code i am trying to run is..
               sql = " insert into DP_TEMP (DP_REF)" + _
                       " select DP_REF " + _
                       " from SY_CSY_CPAT.CITY_DEVELOPMENT_PIPELINES"
               pWS.ExecuteSQL sql
But when the code is run - no errors appear, but the table is empty.
Has anyone got any idea on why it is not working.
Thanks
HalilSiddique
Any inkling anyone?
SachinKanaujia
Are you able to execute the same insert query from a sql prompt or sql editor and not here? Its always better to have a schema name qualification for the tables to be sure that they are modified correctly.
