Copying polylines from one layer to another one results in a multi part feature
1169
04-28-2010 04:56 AM
LuisPenedo
I'm using this code to copy polyline features from one layer to another one but the undisired results is a multipart features.  What am I missing or doing wrong?
public void selectOrphanFeatures(ILayer selLayer, string orphans)
            if (selLayer != null)
                //Get the MxDocument and Map
                if (pMxDoc == null) { pMxDoc = m_app.Document as IMxDocument; }
                if (pMap == null) { pMap = pMxDoc.FocusMap as IMap; }
                String[] linkPVIDs = orphans.Split(',');
                for (int p = 0; p<linkPVIDs.Length; p++)
                    // 5.10.2.18 ----  The orphaned PVIDs records are added to the fallout layer
                    IFeatureClass featureClassOut = OpenFeatureClass(@"d:\", "FALLOUT LAYER");
                    if (featureClassOut == null)
                        throw new Exception("Cannot Open Output FeatureClass");
                    IFeatureLayer featureLayer = selLayer as IFeatureLayer;
                    IFeatureClass featureClass = featureLayer.FeatureClass;
                    IWorkspaceFactory workspaceFactory = new ESRI.ArcGIS.DataSourcesFile.ShapefileWorkspaceFactoryClass();
                    IFeatureWorkspace pFWS = (IFeatureWorkspace)workspaceFactory.OpenFromFile(@"d:\", 0);
                    IFeatureCursor featureCursorInsert = featureClassOut.Insert(true);
                    IFeatureBuffer featureBufferInsert = featureClassOut.CreateFeatureBuffer();
                    IFeatureCursor featCursor = featureClass.Search(null, false);
                    IFeature feature;
                    while ((feature = (IFeature)featCursor.NextFeature()) != null)
                        if (linkPVIDs
== feature.get_Value(feature.Fields.FindField("LINK_ID")).ToString())
                            featureBufferInsert.Shape = feature.Shape;
                            // Add all the original feature's fields to the feature buffer.
                            AddFields(featureBufferInsert, feature);
                            // Insert the feature into the cursor.
                            featureCursorInsert.InsertFeature(featureBufferInsert);
                            featureCursorInsert.Flush();
LuisPenedo
What I am getting is a layer with all features I want to copy right there (that is OK) but when I select one, all of them become selected like if they are a multi part feature.  When I try to explode them with the arcmap advance editing tool, it is not able to do it.  What is wrong?
JohnHauck
Not sure what's happening in your AddFields method. Try adding both feature classes to a map and hard coding a subset of your orphan list to see if it will help track down the problem.  Here is the code I tested from your sample code and had no problem:
IMap pMap = m_hookHelper.FocusMap;
String[] linkPVIDs = new String[] { "1", "2", "3" };
    IFeatureLayer fallOutLayer = (IFeatureLayer)pMap.get_Layer(1);
    IFeatureClass featureClassOut = fallOutLayer.FeatureClass;
    IFeatureLayer featureLayer = (IFeatureLayer)pMap.get_Layer(0);
    IFeature feature;
        if (linkPVIDs
== feature.get_Value(feature.Fields.FindField("Id")).ToString())
LuisPenedo
Thanks!
That made it.  I don't know why I created a workspace when I already had the layer in the table of contents.
Thank you very much again.
Luis F. Penedo
