Converting from geodatabase sde to file gdb
754
03-14-2013 01:49 PM
CarlosCamacho1
Hi.
I am developing an application with ArcObjects libraries and C #. The main function to be performed by the software is to turn features in a remote database Oracle to geodatabase local files at the computer running the application (SDE -> GDB). I've seen some examples on the official site of ESRI, but I failed to get satisfactory results. The version I use is the ArcGIS 10.1 with Visual Studio 2010.
I hope someone can give me your help about it.
Regards.
PS: I am a beginner in developing with ArcObjects libraries.
nicogis
here you can see methods available in ao for transfert datasets http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/0001/0001000003rp000000.htm
