Convert vba code  to C# for arc 10
1111
03-15-2011 12:21 PM
jamescurtis
I have a code snippet of VBA and I need to convert this to C# code Very Quickly. Can anyone help
Private Sub SignPost_MouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
   ' Create connection string to connect to SQL Server
    Dim ConnectStr As String
    ConnectStr = "SERVER=esriappprod.memphis.edu;INSTANCE=5151;VERSION=cpgismob1;USER=cofm;PASSWORD=uofm"
    ' Open the SQL Server Workspace Factory
    Dim pWSF2 As IWorkspaceFactory2
    Set pWSF2 = New SdeWorkspaceFactory
    Dim pWS As IWorkspace
    Set pWS = pWSF2.OpenFromString(ConnectStr, 0)
    ' Start Editing
    Set pWSEdit = pWS
    pWSEdit.StartEditing True
    pWSEdit.StartEditOperation
    ' Open the feature class
    Dim pFeatureWS As IFeatureWorkspace
    Set pFeatureWS = pWS
    Dim pFClass As IFeatureClass
    Set pFClass = pFeatureWS.OpenFeatureClass("COFM.SignPost")
    ' Create new Feature Layer and Point.
    Dim pFL As IFeatureLayer2
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Set pMap = pMxDoc.FocusMap
    Dim pBasicMap As IBasicMap
    Set pBasicMap = pMap
    Dim pMxApplication As IMxApplication
    Set pMxApplication = Application
    Dim pRow As IRow
    Dim pRowObj As IRowEdit
    Set pRow = pRowObj
    Dim pMVal As Long
    Set pFeat = pFClass.CreateFeature
    Dim pPoint As IPoint
    Set pPoint = pMxDoc.CurrentLocation
    Set pFeat.Shape = pPoint
    Dim pEnvelope As IEnvelope
    Set pEnvelope = pPoint.Envelope
    Dim pIdObj As IIdentifyObj
    Dim pFeatIdObj As IFeatureIdentifyObj
    Set pFeatIdObj = New FeatureIdentifyObject
    pFeatIdObj.Feature = pFeat
    Set pIdObj = pFeatIdObj
    pIdObj.Flash pMxApplication.Display
    pFeat.Store
    pMap.SelectByShape pEnvelope, pMxApplication.SelectionEnvironment, True
    'Populates the "MOBILEUPDATE" field with the date and time the point was created
    Dim MyDate As Date
    MyDate = FormatDateTime(Now, vbGeneralDate)
    pFeat.Value(pFeat.Fields.FindField("MOBILEUPDATE")) = MyDate
    pFeat.Store
    'Records VersionName and EditorName
    Dim pVer As String
    pVer = ("cpgismob1")
    pFeat.Value(pFeat.Fields.FindField("MOBILEVERSION")) = pVer
    Dim strNew As String
    strNew = LCase(strUserName)
    pFeat.Value(pFeat.Fields.FindField("MOBILEEDITOR")) = strNew
    ' Stop Editing and refresh active view
    Dim pAV As IActiveView
    Set pAV = pMap
    pWSEdit.StopEditing True
    pWSEdit.StopEditOperation
    pAV.Refresh
End Sub
MichaelRobb
Honored Contributor
I would think going from VBA to VB.net would be easier.
Also, (Set pMxDoc = ThisDocument) is NOT going to work in either vb.net or C#
You will have to do a hook on the application or the IApplication.
m_application as IApplication
m_application = DirectCast(hook, IApplication)
if your running outside ArcMap, you have to go through the Approt and see which session you are using.
Then you can
pMxdoc = m_application.Document (Rather than THISDocument)
Or if you are running on a form created, I do it this way...
In the Command (Button)
In the ONCLick Event ICommand.CLick
'issue with the below, is the form duplicates
             Dim f1 As New frmUpdatePoints
                'pass the m_application along...
                f1.ArcGISApplication = m_application
                f1.Show() ' dont need anything back but keeps from the user playing with Arc while form is open
In the FORM
    Private m_application As ESRI.ArcGIS.Framework.IApplication
Public WriteOnly Property ArcGISApplication() As ESRI.ArcGIS.Framework.IApplication
        Set(ByVal value As ESRI.ArcGIS.Framework.IApplication)
            m_application = value
        End Set
    End Property
now you can use m_application as before
Have you tried any of the converters available online?
jamescurtis
Thanks for your replay. But, the part you commented on i have done already. I basically need to know how to open featurelayer and add a point to it.
MichaelRobb
Honored Contributor
But the part you have done was not mentioned in your initial post, nor was the fact that you were specifically looking for open featurelayer and adding a point.  Just saying, makes it somewhat difficult.
Also, correcting 'ThisDocument' issue you would have had, I would have thought would have been more of an issue than adding a featurelayer... (CartoClass)
Use the API's provided by ESRI or C# Developer Kit or perhaps someone with extensive C# can help you.
And will look something like this:
            IFeatureLayer featureLayer = new FeatureLayerClass();
            IFeatureClass featureClass = featureLayer.FeatureClass;
