Connect from ArcObjects 10.1 Java (1.5) to ArcSDE (10.1) + PostgreSQL (9.0.5)
3074
10-04-2012 07:52 AM
MarcosRodriguez_Gómez
Hi.
I'm developing a Java main app with ArcObjects 10.1, when I run this app and it tries to connect to ArcSDE 10.1 (over PostgreSQL 9.0.5) I get the following error:
AutomationException: 0x8004156b -
at com.esri.arcgis.datasourcesGDB.SdeWorkspaceFactory.open(Unknown Source)
at es.edb.prueba.conexiones.ConexionSDE.conectar(ConexionSDE.java:52)
at es.edb.prueba.principal.PruebaAO.main(PruebaAO.java:50)
If I change the PropertySet with ArcSDE 9.3.1 + Oracle 10g connection params it gets success.
What should I do for solving this problem? Should I intall PostgreSQL client in client machine? Where?
Thanks in advance,
Marcos.
My connection code:
        public void conectar() {
  PropertySet propSet = null;
  try {
   // Create a WorkspaceFactory object within the Server's context
   gWorkspaceFactory = (SdeWorkspaceFactory) ConexionAGS.crearObjeto(SdeWorkspaceFactory.getClsid());
   // Create an instance of a PropertySet for an Oracle ArcSDE connection.
   // The PropertySet acts as an array of keyed values that ArcSDE will use to collect
   // the connection values from:
   propSet = (PropertySet) ConexionAGS.crearObjeto(PropertySet.getClsid());
   propSet.setProperty("SERVER", "my_server_name");
   propSet.setProperty("INSTANCE", "5151");
   propSet.setProperty("DATABASE", "arcsde");
   propSet.setProperty("USER", "sde");
   propSet.setProperty("PASSWORD", "passwordsde");
   propSet.setProperty("VERSION", "SDE.DEFAULT");
   // Open the ArcSDE workspace and get a handle to it through the WorkspaceFactory,
   // passing in the PropertySet
   gWS = gWorkspaceFactory.open(propSet, 0);
   Cleaner.release(propSet);
   // You now have a connection to the database through a Workspace object (gWS).
  } catch (Exception e) {
   e.printStackTrace();
Configuration:
Java 1.6
arcobjects.jar 10.1
ArcSDE 10.1
PostgreSQL 9.0.5
Server Operating System: W2003 Server Standard 64 bits
Client Operating System (where I run Java main app): Windows 7 Professional 64 bits
LeoDonahue
Which line in your code is line #52?
My code is slightly different, but I see that you are using server contexts.
And I don't know what object gWS is, based on your sample.
        // Create a propertySet that contains the connection information to ArcSDE
            IPropertySet propertySet = new PropertySet();
            propertySet.setProperty("SERVER", "server name");
            propertySet.setProperty("INSTANCE", "instance name");
            propertySet.setProperty("DATABASE", "database name");
            propertySet.setProperty("USER", "user name");
            propertySet.setProperty("PASSWORD", "user password");
            propertySet.setProperty("VERSION", "sde.DEFAULT");
            // Create a SdeWorkspaceFactory and open it
            IWorkspaceFactory sdeworkspaceFactory = new SdeWorkspaceFactory();
            IWorkspace workspace = new Workspace(sdeworkspaceFactory.open(propertySet, 0));
Hi Leo.
My code line #52 is:
I connect to ArcSDE 10.1 (+ PostgreSQL 9.0.5) from ArcCatalog and ArcMap without problem with the same connection params.
I change my sample connection code to clarify:
public void conectar(ParametrosSDE parametrosConexion) {
  try {
   IWorkspaceFactory gWorkspaceFactory = (SdeWorkspaceFactory) ConexionAGS.crearObjeto(SdeWorkspaceFactory.getClsid());
   PropertySet propSet = (PropertySet) ConexionAGS.crearObjeto(PropertySet.getClsid());
   IWorkspace gWS = gWorkspaceFactory.open(propSet, 0);
Marcos.
