COMException (0x80050154) DB_xml_parse_doc
591
01-18-2012 02:39 AM
JoergWeigel
Hello all,
what could cause the following error?
System.Runtime.InteropServices.COMException (0x80050154): A syntax error was found in the XML document. [DB_xml_parse_doc: A syntax error was found in the XML document::Invalid document structure, line 1, char 1]
   bei ESRI.ArcGIS.Geodatabase.IVersionEdit3.Post(String VersionName)
Our standalone application worked for a while, then we are consistently getting this error. We are using ArcGIS 10.
Jörg
