Clearing a combobox of Previous Selections!
1482
03-13-2013 05:36 AM
MichelleCouden1
I am loading comboboxes upon selection of previous comboboxes selections. I am having trouble clearing the box so that only the AddItems will show. For Example: Depending on what year they select only certain city names should show in the last combobox. But the combobox instead of clearing just keeps adding the city names. I have .Clear programmed but it's not working.  I've included my code below:
Private Sub UserForm_Initialize()      Dim WorkDB As DAO.Database     Dim workRecSetA As DAO.RecordSet     Dim workRecSetB As DAO.RecordSet     Dim x As Integer                    Set WorkDB = DBEngine.OpenDatabase("K:\TASS\2 - GEO-DATA PROCESSING SUPPORT\MICHELLE'S WORK_ENTER NOT!!\Work Folder\Map Automation Project\Access Tables\Map_Automation.mdb")     Set workRecSetA = WorkDB.OpenRecordset(Name:="select * from Districts order by District_Name", Type:=dbOpenDynaset)     Do Until workRecSetA.EOF         cboDistrict.AddItem workRecSetA("District_Name")         workRecSetA.MoveNext     Loop     Set workRecSetB = WorkDB.OpenRecordset(Name:="select * from Stations order by Station_Name", Type:=dbOpenDynaset)     Do Until workRecSetB.EOF         cboStations.AddItem workRecSetB("Station_Name")         workRecSetB.MoveNext     Loop          For x = 2010 To 2015         cboYear.AddItem x     Next            End Sub  Private Sub cmdCancel_Click()      frmMapSetUp.Hide      End Sub Private Sub cboStations_Change()            If cboStations.Text = "Urban" Then         cboYear.Clear       cboYear.AddItem "2010"       cboYear.AddItem "2011"       cboYear.AddItem "2012"                                    End If                   End Sub Private Sub cboYear_Change()               If cboYear.Text = "2010" Then           cboDistrict.Clear         cboDistrict.AddItem "Abilene"         cboDistrict.AddItem "Amarillo"         cboDistrict.AddItem "Austin"         cboDistrict.AddItem "San_Antonio"         cboDistrict.AddItem "Waco"         cboDistrict.AddItem "Wichita_Falls"     ElseIf cboYear.Text = "2011" Then           cboDistrict.Clear         cboDistrict.AddItem "Beaumont"         cboDistrict.AddItem "Houston"     ElseIf cboYear.Text = "2012" Then           cboDistrict.Clear         cboDistrict.AddItem "Brownwood"         cboDistrict.AddItem "Bryan"         cboDistrict.AddItem "Childress"         cboDistrict.AddItem "Corpus_Christi"         cboDistrict.AddItem "El_Paso"         cboDistrict.AddItem "Lubbock"         cboDistrict.AddItem "Odessa"         cboDistrict.AddItem "Yoakum"                          End If                       End Sub
MichelleCouden1
MichelleCouden1
Forgot to tell you all this program is in VBA (ArcObjects) 6.0!!
MichelleCouden1
Answered!!!
JasonPike
Please post the answer if you are going to mark a thread as answered. That way, if someone has a similar question, they can see your solution.
Thanks.
