Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
888
03-17-2011 05:24 AM
IanShephard
Hi
I'm migrating an application written using VB6 and ArcObjects to .NET
After a machine rebuild, the application started to fail with the above error when OnCommand_OnClick is executed.
The project properties Complie tag has the target machine set as X86.
I have tried to register associated DLLs using Regsvr32 but this results in
"****.dll was loaded, but the DllRegisterServer entry point was not found. This file can not be registered"
I have also ran (again) the regasm utility on the main DLL but still get the above message.
Any help would be much appreciated
Ian
nikhilsastikar
Try to set the target platform as x86 and then compile and run the project
Nikhil
