Changing the mouse cursor back to the Select elements tool after VBA code is executed
1466
05-13-2010 06:12 AM
DavidKelly1
This is probably easy but I am not sure how to do it.  I have a custom tool I developed in VBA; once the tool is used I want to change the mouse cursor back to the Select elements tool.
Thanks for your help
David Kelly
DavidKelly1
I have been trying to change the mouse cursor.  Why does the code below not work.  It bombs when it set the value of UID.
  Dim pCmdBars As ICommandBars
  Set pCmdBars = ThisDocument.CommandBars
  Dim pCmdItem As ICommandItem
  Dim pUID As New UID
  pUID.Value = "{C22579D1-BC17-11DO-8667-0000F8751720}"
  'pUid.Value = "{esriArcMapUI.SelectTool}"
  Set pCmdItem = pCmdBars.Find(pUID)
  'sets the cursor to the Select Elements tool
  pCmdItem.Execute
David
NirYoscovitz
Hi David,
There is a nasty typo in the UID value supplied.
It should be "{C22579D1-BC17-11D0-8667-0000F8751720}", not "{C22579D1-BC17-11DO-8667-0000F8751720}"
Regards,
Nir
DavidKelly1
Thank you.
