Cannot import ESRI.ArcGIS.Geodatabase
922
10-12-2011 07:00 AM
DougStrech
I am trying to convert vba scripts to .net and some of the broken links are for the IFeatureClass and IFeatureLayer, etc.  I figured out that I need the ESRI.ArcGIS.Geodatabase namespace, however, my only options for Imports are:
ESRI.ArcGIS.ArcMapUI
ESRI.ArcGIS.Desktop
ESRI.ArcGIS.esriSystem
ESRI.ArcGIS.Framework
How do I import the Geodatabase namespace?
JamesCrandall
ESRI.ArcGIS.Desktop
Have you tried set a reference to ESRI.ArcGIS.Geodatabase in your project or is it included in the references list?  Right-click your project in the Solution Explorer and select Properties.  Then click the References tab on the left and see if the reference is there.  If not, add it.
Hopefully this helps!
