can't GetObjectFromFullName with IGxCatalog
1366
07-28-2011 03:05 PM
EvanThoms
In an ArcMap addin I have the code:
Dim gxCat As IGxCatalog
Dim pObj As IGxObject
Dim x As Long
gxCat = New GxCatalogClass
pObj = pObj = gxCat.GetObjectFromFullName(sPath, x)
But the last line trips the error - Cannot convert to 'Interface IGxObject', but that's exactly what the function is documented to do.
I know the path is good (tried a few) and I think I am getting a valid catalog object, I mean, I can do things with it like make a folder connection.
Furthermore, on my previous computer, this same addin and this same chunk of code never threw an error.
BTW, what I am trying to do is, from a full path to an object, determine first if the path leads to a valid ArcCatalog object and then what the datase type of that object is, so if there is another way beside getting to IGxDataset.Dataset.Type I would appreciate it.
Thanks
NeilClemmons
Honored Contributor
This line is incorrect:
It should be:
Also, GetObjectFromFullName may return an IGxObject reference or an IEnumGxObject reference.  Your code should handle the possibility of both.  See the developer help for more info and for an example.
amrutabildikar1
You can refer following VBA example to implement the functionality.
I think you can try to get full name from GetObjectFullName into a variant type of variable.
Sub GetObjFromFullname()
Dim pApp As IGxApplication
Set pApp = Application
Dim pCat As IGxCatalog
   Set pCat = pApp.Catalog
   Dim pGxObject As IGxObject
  Dim numFound As Long
Dim v As Variant
Set v = pCat.GetObjectFromFullName("C:\data\parcels.shp", numFound)    'Assuming the above pathname is valid
   If numFound = 1 Then
   Set pGxObject = v
  Else
  Dim pEnumGxObject As IEnumGxObject
       Set pEnumGxObject = v
   Set pGxObject = pEnumGxObject.Next
   End If
End Sub
I hope this helps!
Good luck!
EvanThoms
Thanks!
Yes, I did find an example of testing for a single or an enumeration reference and it turns out the function is returning an enumeration of three references, all to the exact same object, in this case a tif file (also tried a .asc), which I presume is just one object. And this is probably why my code worked on a different build; it was always only returning a single reference. So, why am I getting three now?
EvanThoms
And another weird thing is happening I didn't at first think was related. When
pObj = gxCat.GetObjectFromFullName(sPath, numFound)
is called, an unnamed .prj file appears in the folder alongside the mxd that has the addin with the spatial reference of the tif file at the end of sPath.
