Can't find MapFrame of GraphicsContainer in PageLayoutControl (C#) ?
2367
5
02-17-2013 11:04 PM
TaiBui
I am getting a problem: I added element (text, line) in a ActiveView.FocusMap of a PageLayoutControl, then all elements are showed in the MapFrame of PageLayoutControl.GraphicsContainer.
If I don't select elements (in MapFrame) I can find the MapFrame by the loop:
IGraphicsContainer graphicsContainer = myPageLayout.ActiveView.GraphicsContainer; graphicsContainer.Reset(); IElement pElement = graphicsContainer.Next();  while (pElement != null)             {                 if (pElement is IMapFrame)                 {                       // do something                  }             }
But, when one element is selected by using "Select Elements" command, the program won't enter the "if" function (can't find MapFrame).
Are there anyone know how to get The MapFrame in this case ?
It's very urgent
Thank you very much !
SiqiLi
by Esri Contributor
Thanks Shuping,
Yes, in my code, I didn't include line: pElement = graphicsContainer.Next(); in the while loop.
In your code, you selected shapes of the pagelayout, right ? Is it ok if you add and select shapes within the Focus Map (MapFrame) of the pagelayout ?
Kind regards,
Hi taibc, sorry for the late reply. I think I know what you mean now.
Try to replace:
 IGraphicsContainer graphicsContainer = axPageLayoutControl1.ActiveView.GraphicsContainer
by:
 IGraphicsContainer graphicsContainer = axPageLayoutControl1.GraphicsContainer;
It works at my end.
TaiBui
Are there anyone can help ?
SiqiLi
by Esri Contributor
Just tested and it works fine at my end. See the attached screen shot.
BTW, your code has an infinite loop!
Let me know if I misunderstood the issue. [ATTACH=CONFIG]22040[/ATTACH]
TaiBui
Thanks Shuping,
Kind regards,
SiqiLi
by Esri Contributor
Thanks Shuping,
Kind regards,
Try to replace:
by:
It works at my end.
TaiBui
Great ! It is successful now.
Thanks Shuping very much  !
Kind regards,
