calculating polyline length in a polygon
2145
02-22-2011 11:47 AM
davidwelch
using arcgis 9.3.1,
I would like to calculate polyline length within polygons (they are overlapping)
with smaller file size the intersect command and tabular analysis did the trick.
the current polygon file I have has ~50,000 records, which will create too large of a file size.
I am not versed in any language (VBA, python); so I'll consider any approach you can suggest and try to make it work.
   thanks
WoodrowFields
It sounds like you may want to try using the Clip tool to clip out everything in the polyline feature class that is not within a polygon.  Then with the new clipped feature you could use "Calculate Geometry" by right clicking on a column in the attribute table and choose Length as the property to calculate.
