Build Failed - Failed to register Add-in
13866
13
09-07-2010 04:06 PM
MikeLouwrens
I have been going through the Add-in walkthrough and when I try to Build I get an error "Failed to register Add-in 'CustomUIElements.esriAddIn'"
This is the Build Output:
------ Build started: Project: CustomUIElements, Configuration: Release Any CPU ------
C:\WINDOWS\Microsoft.NET\Framework\v3.5\Csc.exe /noconfig /nowarn:1701,1702 /errorreport:prompt /warn:4 /define:TRACE /reference:C:\ArcGIS\DeveloperKit10.0\DotNet\ESRI.ArcGIS.ArcMapUI.dll /reference:C:\ArcGIS\DeveloperKit10.0\DotNet\ESRI.ArcGIS.Carto.dll /reference:C:\ArcGIS\DeveloperKit10.0\DotNet\ESRI.ArcGIS.Desktop.AddIns.dll /reference:C:\ArcGIS\DeveloperKit10.0\DotNet\ESRI.ArcGIS.Display.dll /reference:C:\ArcGIS\DeveloperKit10.0\DotNet\ESRI.ArcGIS.Framework.dll /reference:C:\ArcGIS\DeveloperKit10.0\DotNet\ESRI.ArcGIS.Geometry.dll /reference:C:\ArcGIS\DeveloperKit10.0\DotNet\ESRI.ArcGIS.System.dll /reference:"c:\Program Files\Reference Assemblies\Microsoft\Framework\v3.5\System.Core.dll" /reference:"c:\Program Files\Reference Assemblies\Microsoft\Framework\v3.5\System.Data.DataSetExtensions.dll" /reference:C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.dll /reference:C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.dll /reference:C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.dll /reference:C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.dll /reference:C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Xml.dll /reference:"c:\Program Files\Reference Assemblies\Microsoft\Framework\v3.5\System.Xml.Linq.dll" /debug:pdbonly /filealign:512 /optimize+ /out:obj\Release\CustomUIElements.dll /target:library Properties\AssemblyInfo.cs ZoomToLayerButton.cs AddGraphicsTool.cs Config.Designer.cs
Compile complete -- 0 errors, 0 warnings
CustomUIElements -> C:\VisualStudio\Projects\CustomUIElements\CustomUIElements\bin\Release\CustomUIElements.dll
Successfully created Add-in "CustomUIElements" -> 'C:\VisualStudio\Projects\CustomUIElements\CustomUIElements\bin\Release\CustomUIElements.esriAddIn'.
esriRegAddin.exe "C:\VisualStudio\Projects\CustomUIElements\CustomUIElements\bin\Release\CustomUIElements.esriAddIn" /s
C:\Program Files\MSBuild\ESRI\ESRI.ArcGIS.AddIns.targets(125,5): error : Failed to register Add-in 'CustomUIElements.esriAddIn'.
Done building project "CustomUIElements.csproj" -- FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
Software:
Visual Studio 2008
ArcGIS 10
XP Pro 32bit
I didn't use the sample data, just followed the walkthrough and ran Build when it told me to ("Installing the custom button and tool" section)
Any ideas on what's happening?
Cheers,
Mike.
RobynGingerich
Hi All,
I experienced the same issue when trying to install the AttributeAssistant and WaterUtility Network Editing Tools in my Desktop version 10.2.  I received a pop-up with the following message:  Installation failed. Access is denied. The specified add-in file may be in use.
I was able to resolve this problem by putting the add-in installer files in the following directory:  C:\Program Files (x86)\ArcGIS\Desktop10.2\bin\Addins.  You can actually put the installer files in any directory and then add it through the the options dialog of the Customize -> Add-in Manager in ArcMap.
Well that worked for me anyway.  I hope it works for you too.
Regards,
gingerrc4
deleted-user-amp86F9KgPL3
YES YES AND YES!!! Thank You!!! robyn@edcgov
Town_of_Fuquay-Varina_GIS
I recently had this issue where we were suddenly unable to use an add-in that we have had on a network folder for years with no problems. We made certain changes to the way we map our user's desktops/profiles, involving Sharepoint directories.
Copying the add-in file to the Add-In folder on each users machine works for us! However, it only appears in ArcMap and not in Catalog for some reason. Windows 7, ArcGIS Desktop 10.5
FabianHeredia
the problem is:
you look "Config.esriaddinx" in line
<Targets>
    <Target name="Desktop" version="10.0" />
  </Targets>
the Solution
change the version API
