Buffer geometries using IBufferConstruction() and IBufferConstructionProps
2177
07-07-2010 05:53 PM
ChrisWheldon
Ladies and Gents
This is what I am briefly trying to do. Buffer polylines using IBufferConstruction and IBufferConstructionProperties because I want to obtain mitred (flat) ends to the buffers. I would also like to parse in a field value as the buffer distance. I have got so far as to use the ITopologicalOperator but I am really struggling with a link to the IEnumGeometry and IGeometryCollection in the code. I have got to a point where I don't know what's what anymore.
I have been calling the module from my ThisDocument module using a UI button and passing in the buffer distance using an inputbox.
I hope someone can help me continue on. I am doing this because my highest licence seat is Editor.
Thank you
Chris
New Zealand
AlexanderGray
Honored Contributor
Have you tried calling createfeaturebuffer from within the loop where you insert the features.  I have always created a new featurebuffer for each individual feature I insert.
ChrisWheldon
Hi Alexander
Thanks for replying. I have not tried what you suggest as yet. I am trying to get my selected features into a geometry collection at the moment so that I can enumerate through them and pass each feature as input into the IBufferConstruction. Theoretically easy enough.
Regards
Chris
ChrisWheldon
Hi all
I nearly have my buffers using IBufferConstruction. Using the code attached I am able to place the records in the table but NOT see the associated geometries, and of course I don't know why. The offending code is in the Do Until loop where I take the enumerated feature and try to pass this, with a buffer distance into the bufferconstruction method. I'm not sure if my use of the GeometryCollection output is correct. Using ITopologicalOperator works fine and is commented out because I wish to eventually get to IBufferConstructionProps.
Appreciate any help. I just need someone to see what I'm not.
Chris
ChrisWheldon
Hi
Can anyone out there see why I am getting records in the table but no geometries to match ?
Do Until pFeature Is Nothing
        Application.StatusBar.Message(0) = "Buffering " & l & " of " & d
        Set inputPolyline = pFeature.ShapeCopy
        'Set inputPolyline = pFeature.ShapeCopy
        Set pGeomColl = New GeometryBag
        pGeomColl.AddGeometry inputPolyline
        Set pEnumGeometry = pGeomColl
        pEnumGeometry.Reset
        'MsgBox "Geometry Count: " & pGeomColl.GeometryCount
        Set pGeo = pEnumGeometry.Next
        i = 1
        While Not pGeo Is Nothing
            'MsgBox "Geometry: " & i & " Geometry type: " & pGeo.GeometryType
            Dim pBC As IBufferConstruction
            Set pBC = New BufferConstruction
            'Dim pPolygon As IPolygon
            'Set pPolygon = pBC.Buffer(pGeo, dDist)
            Set pOutGeomColl = New GeometryBag
            Dim pOutPoly As IPolygon
            Set pOutPoly = New Polygon
            pOutGeomColl.AddGeometry pOutPoly
            pBC.ConstructBuffers pEnumGeometry, dDist, pOutGeomColl
            Set pNewFeature = pInsertFeatureBuffer
            Set pNewFeature.Shape = pOutPoly
            q = pInsertFeatureCursor.InsertFeature(pInsertFeatureBuffer) 'Insert the feature into the feature cursor
            i = i + 1
        Wend
        Set pFeature = pFeatureCursor.NextFeature
        l = l + 1
    Loop
Chris
