Best way to return spatial query reuslts
795
07-17-2013 01:11 PM
olivermcrobbie1
a non-gis developer needs to be able to get the results of a simple spatial query, which will be used in an ASP.NET application.  The obvious solution was to create a service that performs the query, which she would then consume in her app.  Using Visual Studio I created a WCF service that did the job, but after publishing it I get this error: "Could not load file or assembly 'ESRI.ArcGIS.Display' or one of its dependencies. An attempt was made to load a program with an incorrect format".  I noticed that my arcobjects code throws a bunch of warnings when the processor target is set to "any cpu", no warnings if I change it to "x86".  I've read that WCF services can't target x86.  I'm unsure if I should continue pursuing this solution or I should change my approach.  I'm still new to the api, so any help is more than appreciated.    Thanks.
