ARCREADER(AxArcReaderControl) Retrieval Process. I was unable to load related tables to the .gdb file along with .pmf file created from local system, from ESRI created sample. I do not want the layer to be clumsy/complicated only tables to be added to th
4391
02-08-2015 10:40 PM
KarunyaLakshmi
ARCREADER(AxArcReaderControl) Retrieval Process. I was unable to load related tables to the .gdb fil...
I do not want the layer to be clumsy/complicated only tables to be added to the geodatabase ,
Geo Database table is related to eleven more tables ,
whenever i quered through ARSearchQuery method only able to receive the data from focused layer table ,
can you help me out in receiving column name from the related table to the currently focused layer.
