Arcobjects sample not running in eclipse
6543
11
09-27-2012 06:06 AM
AvishekDutta
I am new to the world of Arcobjects. To experiment I tried running a sample in eclipse but it pointed out a license issue. I am bit confused now about the pr-requisites so help is much needed.
I am running Desktop 10.1 on windows xp. I have also installed the Arcobjects sdk for Java. I have the license(s) and have already registered the product and extensions.
After configuring eclipse following http://resources.esri.com/help/9.3/arcgisengine/java/doc/91b1bd68-21a5-404d-b0d3-cc55086d2b68.htm (here it talks about ArcGIS engine but I did the same steps for ArcObjects) I was able to add create a "ArcObjects Sample" as a new project in eclipse. This is the custom tool "delete features". When I run the ToolRunner class I get the message "Could not initialize an Engine or Basic License. Exiting application." which comes from the static method initializeArcGISLicenses(AoInitialize aoInit).
Now ArcGIS is already running, so I can not understand where the problem is, I don't have ArcGIS engine but a desktop should do fine?
If you can find time to set me right I would be very grateful.
Avishek
TomSchuller
Hy,
could you post the .jar file or send it per PrivateMessage or mail?
Tom
TomSchuller
Hy,
to start developing GPTools in Java for ArcGIS10.1, just use these pages:
http://resources.arcgis.com/en/help/arcobjects-java/concepts/engine/#/Develop_and_Deploy/0001000006q...
You will also find a guide to use the "DeleteFeatures" example:
http://resources.arcgis.com/en/help/arcobjects-java/concepts/engine/#/Sample_Delete_Features/0001000...
Best regards,
Tom
