ArcObjects - How to conver m-points to a polyline?
2045
12-26-2013 05:59 AM
ShaningYu
Honored Contributor
I am working on an ArcObjects / SOE project.  I need to convert multiple points into a line feature.  Using the approach at http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#/How_to_create_a_polyli..., I got a PolylineClass object: poinColl (its PointCount=213).  In the following step, I tried to cast the PolylineClass object as a Polyline like that
             IPointCollection4 pointColl = CreatePolylineByPoints(pointsCollection, point)  // returns  ESRI.ArcGIS.Geometry.PointClass
             IPolyline polyLine = (IPolyline)pointColl;
The polyLine has no value (e.g. XMax=XMin=...=0.0, MMax=MMin=NaN).
Then I turned to an alternative approach that works for IPointCollection rather than IPointCollection4
            IFeatureClass fc = CreateEmptyPolylineFC(fws, "MyPolyline", sr, routeIdFieldName);
            IFeature polylineFeature = fc.CreateFeature();
            // Assign polyline geometry and M-value
            IPointCollection4 pointColl = (IPointCollection4)polylineFeature;     //(IPointCollection)polylineFeature;
I got InvalidVastException - Unable to cast COM object of type 'System._ComObject' to interface  type 'ESRI.ArcGIS.Geometry.IPointCollection4'...
Another alternative I did was to cast IPointCollection4 object as IPointCollection, but also got InvalidCastException.
What's wrong in my code above?  Thanks for help.
ShaningYu
Honored Contributor
The problem in my 1st thread was solved. I revised the method in http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//0001000000v0000000 as below in order to get the return of a PolylineClass object.
void ESRI.ArcGIS.Geometry.IPointCollection4 CreatePolylineByPoints(List<ESRI.ArcGIS.Geometry.IPoint> pointsCollection) {
//Build a polyline from a sequence of vertices (points).
//Add arrays of points to a geometry using the IGeometryBridge2 interface on the GeometryEnvironment singleton object.
ESRI.ArcGIS.Geometry.IGeometryBridge2 pGeoBrg = new ESRI.ArcGIS.Geometry.GeometryEnvironment()as IGeometryBridge2;
//pPointColl is the new polyline.
ESRI.ArcGIS.Geometry.IPointCollection4 pPointColl = new ESRI.ArcGIS.Geometry.PolylineClass();
//TODO:
//Set pPointColl.SpatialReference = 'Define the spatial reference of the new polyline.
for (int i = 0; i < pointsCollection.Count; i++) { // 200+ points
pPointColl.AddPoint(pointsCollection);
ESRI.ArcGIS.esriSystem.WKSPoint[] aWKSPointBuffer = new ESRI.ArcGIS.esriSystem.WKSPoint[pPointColl.PointCount ];
// 200+ points in aWKSPointBuffer, but each one's X=0.0 and Y=0.0
pGeoBrg.SetWKSPoints(pPointColl, ref aWKSPointBuffer);
return pPointColl;
See the red-marked note. All of the X/Y values are 0.0. I could not figure out why. Please post your comment if you have the knowledge on it. Thanks.
RichardFairhurst
This post was moved to from the General forum to the ArcObjects forum, since it is not a general ArcGIS question.
ShaningYu
Honored Contributor
I have solved this problem by using a simple approach.  The general procedure is below:
1) Create a List<ESRI.ArcGIS.Geometry.IPoint> to collect all of points.
2) Create an object of  ISegmentCollection path = new ESRI.ArcGIS.Geometry.PathClass();
3) Create a segment by entering 2 points (looping the List<ESRI.ArcGIS.Geometry.IPoint>)
4) Add the segment into the path.
            object obj = Type.Missing;
            for (int i = 1; i < pointsCollection.Count; i++)     {
                ILine pLine = CreateLine(pointsCollection[i - 1], pointsCollection);
                path.AddSegment((ISegment)pLine, ref obj, ref obj);
        private ILine CreateLine(IPoint ptA, IPoint ptB)    {
            ILine pLine = new Line();
            pLine.PutCoords(ptA, ptB);
            return pLine;
5) Create a PolylineClass and complete the change
            ESRI.ArcGIS.Geometry.IPolyline pSegPoly = new ESRI.ArcGIS.Geometry.PolylineClass();
            ESRI.ArcGIS.Geometry.IGeometryCollection pGeoColl = pSegPoly as IGeometryCollection;
            pGeoColl.AddGeometry((IGeometry)path, ref obj, ref obj);
            pGeoColl.GeometriesChanged();
