ArcObjects Diagram (AllOMDs) for Arc10
2942
07-17-2011 08:13 AM
CrisjovanoGumaraes
Hi, I am looking for an updated ArcObject Digram PDF. The Last one that I have is the AllOMDs ArcGis 8.3 that I got from EDN. Anybody know where can I get the last one ?
thanks.
Crisjovano.
JohnHauck
I don't believe that we have provided an all inclusive OMD pdf for quite a few years. With the current release you will find a pdf for each unique assemblies OMD after you install the developer kit at:
<Dev Kit Install Dir>\Diagrams
(example: C:\Program Files\ArcGIS\DeveloperKit10.0\Diagrams)
For 9.x it would be located at:
<ArcGIS Install Dir>\DeveloperKit\Diagrams
(example: C:\Program Files\ArcGIS\DeveloperKit\Diagrams)
RichardWatson
You can also access the OMDs online without having to install the developer kit.
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html
For example, if you choose ArcMap then ESRI.ArcGIS.ArcMap you will see ArcMap Namespace Object Model Diagram which takes you here:
http://help.arcgis.com/en/sdk/10.0/Arcobjects_net/pdf/ArcMapObjectModel.pdf
CrisjovanoGumaraes
thanks so much guys. I have tried both options. And I could access the diagrams.
very, very nice. The models in separeted assembly is better.
