ArcObjects access to Geoprocessing Results
1517
11-10-2020 07:51 AM
DJurgella
Is it possible to get access to the geoprocessing results in ArcMap using ArcObjects?  These are the results that show up in the Geoprocessing Results window.  I'm looking to programmatically remove results after they've been run, or prevent results from being added in the first place.  The "Never save" option doesn't work, nor does unchecking "Log operations to a log file".
DJurgella
I used IGeoProcessor2.AddToResults = False to not add the results to the window.
DJurgella
