ArcMap retains fields of removed Table.
1208
03-14-2013 09:37 AM
DuncanHornby
MVP Notable Contributor
All,
I have developed an AddIn for ArcMap 10.1 using VB .net 2010.
My tool writes data it creates to a dBase file which gets loaded into the TOC. During processing the tool can create up to 25 fields.
Sometimes a user will need to rebuild this table with its initial set of 3 fields (by selecting a button on toolbar).
When the user clicks on the create table button my code searches for the table in the TOC and removes it with the following code:
 pStandAloneTableCollection.RemoveStandaloneTable(pStandAloneTable) pMXDocument.UpdateContents()
The code then continues by deleting the existing dBase file and then recreates with the default set of 3 fields. This all works fine. The table is loaded back into the TOC with the following code:
pStandAloneTable = New StandaloneTableClass pStandAloneTable.Table = pTable pStandAloneTable.Name = Me.TextBox1.Text pStandAloneTableCollection.AddStandaloneTable(pStandAloneTable) pMXDocument.UpdateContents()
If I then go to the Table in ArcMap and open it I see all the previous fields (with zero values) and not an attribute table with just 3 fields. It's as if ArcMap has held onto the schema of the table it had removed, any ideas on how to force a refresh?
Duncan
DuncanHornby
All,
FYI I resolved the problem, it appears to be with the way I was deleting the dBase file. Originally I was deleting the table using the following code:
My.Computer.FileSystem.DeleteFile(sFullPath)
I changed this to the more verbose method using ArcObjects:
Dim pWorkspaceFactory As IWorkspaceFactory pWorkspaceFactory = New ShapefileWorkspaceFactoryClass Dim pFeatureWorkspace As IFeatureWorkspace pFeatureWorkspace = pWorkspaceFactory.OpenFromFile(sPath, 0) pTable = pFeatureWorkspace.OpenTable(Me.TextBox1.Text) Dim pDataset As IDataset pDataset = DirectCast(pTable, IDataset) If pDataset.CanDelete Then     ' Delete and clean up     pDataset.Delete()     pTable = Nothing     pTable = Nothing     pFeatureWorkspace = Nothing     pWorkspaceFactory = Nothing End If
This has resolved my problem.
DuncanHornby
All,
