ArcGIS license corrupted by standalone application
2943
08-01-2013 07:46 AM
ArnaudFradin
This is a problem my coworkers and I have encountered several times without being able to track down the exact issue, and a very annoying and almost untestable one.
When testing a standalone application using ArcObjects, at the some point the license would end up corrupted and impossible to repair without contacting ESRI support.
A sample of the latest application in development that corrupted my license recently:
[STAThread]
static void Main(string[] args)
  AoInitialize arcObjectInitialize = null;
 if (!ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop))
  System.Console.WriteLine("This application could not load the correct version of ArcGIS.");
  Environment.Exit(Environment.ExitCode);
 try
  arcObjectInitialize = new AoInitialize();
  esriLicenseProductCode typeLicense;
  if (arcObjectInitialize.IsProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeBasic) == esriLicenseStatus.esriLicenseAvailable)
   typeLicense = esriLicenseProductCode.esriLicenseProductCodeBasic;
   arcObjectInitialize.Initialize(esriLicenseProductCode.esriLicenseProductCodeBasic);
  else
   if (arcObjectInitialize.IsProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeStandard) == esriLicenseStatus.esriLicenseAvailable)
    typeLicense = esriLicenseProductCode.esriLicenseProductCodeStandard;
    arcObjectInitialize.Initialize(esriLicenseProductCode.esriLicenseProductCodeStandard);
   else
    if (arcObjectInitialize.IsProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeAdvanced) == esriLicenseStatus.esriLicenseAvailable)
     typeLicense = esriLicenseProductCode.esriLicenseProductCodeAdvanced;
     arcObjectInitialize.Initialize(esriLicenseProductCode.esriLicenseProductCodeAdvanced);
    else
     throw new Exception("ArcView");
 catch
  Console.WriteLine("No valid license found, exiting program.");
 //Some processings...
 try
  arcObjectInitialize.Shutdown();
 catch
  Console.WriteLine("License shutdown failed, exiting program.");
It follows the examples given on the support, but if there is something more to check or something that shouldn't be done, I woul be really glad to know what. The latest corruption happened while ArcMap was running in background, should it be avoided ? Is it a known issue or is there a way to check if the license is in use ?
