ArcEngine 10 - Cannot get license
2821
10-12-2011 02:38 PM
ESRICustomer
My environment
  • Visual studio 2008
  • ArcEngine 10
  • VB.NET
I choose to start a new project using an ArcGIS TEmplate,
specifically, the "MapControl Application" Template.
I didn't change a single line of code, I simply ran it, and it bombed with
"You must have a license to use this ActiveX control"
Keep in mind, their own template has code in the ApplicationEvents.vb file which checks out an Engine license.
i have BOTH an engine license and desktop license on this computer.
I looked at ESRI's own advice here...
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//0001000002ns000000
...which says to put the license checkout code in the form's Sub New() just before the call to InitializeComponent()
So I did that, ran it, and it bombed again with same message.
I attached the project so you could see for yourself.
I also attached a pic of the relevant code.
Notice in the immediate window that i have licenses.
I don't know how to get this to work programmatically.
I do NOT want to use a license control because of the nature of our application. People need to be able to start the application and use parts of it other than the map without checking out a map license, and the only way to do that is programmatically check out the license just before it's needed.
Any help is appreciated.
Thanks.
by Anonymous User
Not applicable
Original User: CCPoston
Create a "Windows Application (Engine)" and I think you'll see that the binding must be a target of the ResolveBindingEvent. You can't just do it and be done.  You must set up the mechanism so it can be checked when necessary.
