ApplicationStatusEvents throws COM exception
1116
01-06-2011 09:27 AM
KenSimoncic
I have some code that worked in VB6 (Arc 9.3) but is now throwing a COM error in VB.NET (Arc 10).
The code  declares at the top:
Private WithEvents pApplicationStatusEvents As ESRI.ArcGIS.Framework.ApplicationStatusEvents
Then later we have:
    Private Sub IExtension_Startup(ByRef initializationData As Object) _
    Implements ESRI.ArcGIS.esriSystem.IExtension.Startup
        Try
            If (TypeOf initializationData Is ESRI.ArcGIS.Framework.IApplication) Then
                m_pApp = initializationData
                pApplicationStatusEvents = m_pApp
            End If
When it executes the pApplicationStatusEvents = m_pApp line, I get the following error:
Unable to cast COM object of type 'System.__ComObject' to interface type 'ESRI.ArcGIS.Framework.ApplicationStatusEvents'.  This operation failed because the QueryInterface call on the COM component for the interface with IID '{...}' failed due to the following error: No such interface supported (Exception fro mHRESULT: 0x80004002 (E_NOINTERFACE)).
Does anyone know if this capability has gone away?  I think what it was supposed to do in call the Initialize method when the applications gui was fully initialized but I could be wrong.  I inherited this code and I'm not sure of all of its quirks.
AlexanderGray
Honored Contributor
Events in .NET are still there, you just need to set them up differently.  The developer help for .net explains how to do it
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/How_to_wire_ArcObjects_...
