Application (.EXE) Error
879
03-07-2011 03:13 AM
UsmanJamil
Hello every one,
i am facing an issue while trying to run an engine application from .exe file on a system that has .NET framework and ArcGIS desktop installed. When i double click the .exe file from the debug folder to run the application, its gives an error "Application has stopped working". Screenshot is attached herewith. the application is working on some systems, while on some it gives this error.
i am sure amny of you would have faced this problem while deploying engine applications. can any one help with the problem?? thanking you in advance!
Best Regards,
Usman Jamil
